You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
ASA 5500 series question
I need confirmation on the following: can cisco secure desktop software be used with an asa-5505 or is a asa-5500 device needed?
  • LAN Switching and Routing
Re: ASA 5500 series question
All ASA 55xx boxes support Cisco secure desktop version 3.1.1 and later
CSD 3.1.1 requires ASA's running a code of 7.1(1) or later while all the newer versions require version 8.0
CSD 3.1 & 3.1.1 is also supported on Cisco VPN 3000 concentrator and also on the 6500 webvpn module
Narayan
So if I purchase several ASA-5505's and place them in different remote offices, I do not need an ASA-5500 back at the main shop correct? thanks
113
