ASA 5500 Terminal update messages.
elcephus1
I am trying to access my Csico ASA 5500 and when I log in I keep getting these update messages. I have tried "undebug all", "terminal no monitor" and still the messages appear.  Any insight into this would be much appreciated.
181.58/52789
%ASA-6-302013: Built outbound TCP connection 4038140 for outside:206.190.60.37/8
0 (206.190.60.37/80) to inside:10.10.15.117/3564 (208.251.181.58/52789)
%ASA-6-302014: Teardown TCP connection 4038140 for outside:206.190.60.37/80 to i
nside:10.10.15.117/3564 duration 0:00:00 bytes 711 TCP Reset-I
%ASA-6-106015: Deny TCP (no connection) from 206.190.60.37/80 to 208.251.181.58/
52789 flags FIN ACK  on interface outside
%ASA-6-302020: Built inbound ICMP connection for faddr 10.10.10.14/512 gaddr 10.
10.15.10/0 laddr 10.10.15.10/0
%ASA-6-302020: Built outbound ICMP connection for faddr 10.10.10.14/512 gaddr 10
.10.15.10/0 laddr 10.10.15.10/0
%ASA-6-302021: Teardown ICMP connection for faddr 10.10.10.14/512 gaddr 10.10.15
Jerry Ye
conf t
no logging console
HTH,
jerry
Nice - worked like a charm.
Thanks.
Question, is this an ASA5500 command or will it work on other routers? Why the differences on the IOSs ,or is there none? Just curious.
Jeffrey
It happens that no logging console is also a valid command on routers and IOS switches (and has the same effect). The OS of the ASA is quite different from IOS (it is a box built for a very different purpose) and many commands use somewhat different syntax. But there are some that are exactly the same on ASA and in IOS.
Rick
Rick
Nagaraja Thanthry
Please try "no logging console".
Hope to help.
NT
