ASA 5505 Cannot ping from inside interface to outside interface
Greetings,
I am new to the Cisco ASA.  I have a Cisco ASA 5505 and I have my internal and external interfaces configured but I currently cannot ping from the inside to an IP Address on the outside.  I had this setup and working and I have another set of equirement that I am replacing that is working with my service provider so I know it is a configuration issue.  When I ping 4.2.2.2 for example I get:
  Destination host unreachable
Do I need to add a static route from my inside interface to my outside interfaces?
Here is my configuration.  Please advise.
: Saved
ASA Version 8.2(5)
hostname pxasa
enable password <removed> encrypted
passwd <removed> encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address <##.##.##.##> 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server 184.16.33.54
access-list outside_nat0_outbound extended permit ip any <##.##.##.##> <##.##.##.##>.0
access-list outside_access_in extended permit tcp <##.##.##.##> <##.##.##.##> <##.##.##.##> <##.##.##.##> eq https
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool VPNIP-Pool <ip removed>-<ip removed> mask <ip removed>.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-645.bin
no asdm history enable
arp timeout 14400
global (outside) 1 <ip removed>
nat (outside) 0 access-list outside_nat0_outbound outside
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http <##.##.##.##> <##.##.##.##> inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto ca trustpoint ASDM_TrustPoint0
enrollment self
fqdn pxasa.nullvpn2.predixionsoftware.com
subject-name CN=vpn2.predixionsoftware.com
keypair sslvpnkeypair
crl configure
crypto ca certificate chain ASDM_TrustPoint0
certificate
    <removed>
  quit
no vpn-addr-assign aaa
no vpn-addr-assign dhcp
vpn-addr-assign local reuse-delay 10
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl trust-point ASDM_TrustPoint0 outside
webvpn
enable inside
enable outside
svc image disk0:/anyconnect-win-2.5.2014-k9.pkg 1
svc enable
internal-password enable
group-policy SSLGroupPolicy internal
group-policy SSLGroupPolicy attributes
wins-server none
dns-server value 184.16.33.54
vpn-tunnel-protocol svc
default-domain none
address-pools value VPNIP-Pool
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
group-policy GroupPolicy1 internal
group-policy GroupPolicy1 attributes
wins-server none
default-domain none
username Predixion password <removed> encrypted privilege 0
username Predixion attributes
vpn-group-policy DfltGrpPolicy
username cisco password <removed> encrypted
tunnel-group vpn2.predixionsoftware.com type remote-access
tunnel-group vpn2.predixionsoftware.com general-attributes
default-group-policy SSLGroupPolicy
dhcp-server <##.##.##.##>
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
: end
Everyone's tags (2)
Try by adding.. 'inspect icmp' in 'policy-map global_policy' config.
hth
MS
Jeff,
I'm assuming that you're supposed to be natting on this ASA. The nat statement is missing. In addition to what was stated above with the inspect, you'll need to add another nat statement:
global (outside) 1
nat (inside) 1 0.0.0.0 0.0.0.0
NAT 0 bypasses nat altogether, so I'm not 100% certain what you're trying to accomplish there. You may not need nat on this device at all, but if so add the above lines to see if it helps.
HTH,
John
HTH, John *** Please rate all useful posts ***
4604
