ASA 5505 connected to WS-C3560G-48PS
latintrpt
I recently removed a catalyst 2950 switch code version: c2950-i6q4l2-mz.121-13.EA1
I had an ASA 5505 connected as a switchport access to the 2950 on port 44.  We will call the VLAN that the ASA sits on: VLAN 404.  The 2950 had a trunk to our catalyst 6509 distribution switch carrying that VLAN 404.  We also have a another VLAN for computers that sits on: VLAN 129, this is a standard DHCP vlan and it accounted for the rest of the switchports.  The 2950 also has this trunked to our 6509 distribution switch.
Everything was working fine with that setup.
After replacing the 2950 with a 3560 we started running into problems.  The 3560 was configured the same exact way as the 2950.  What was happening is that computers that sat on VLAN 129 started experiencing packet loss and were unable to work.  It's as though the ASA was taking over the switch.
Is there a protocol that is enabled by defult on the 3560 that would do this?
Thanks, hope that makes sense
cadet alain
Can you post 3560 config and explain exactly what is happening in this VLAN 129.
Regards.
Alain.
zain_gabon
Hi, check both 3560 and 6509 trunk configurations, don't forget the encapsulation, because on 2950 when configuring the trunk, we don't specify the encapsulation,and on 3560, you need to specify it,
if you can only post the both switch trunk configurations
I have checked both sides, switch trunk encapsulation dot1q is setup.
Here is an output of the 2950: (WORKING)
cat2950a>en
Password:
cat2950a#sh run
Building configuration...
Current configuration : 9416 bytes
! Last configuration change at 10:07:30 CENTRAL Thu Nov 3 2011 by
version 12.1
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname cat2950a
aaa new-model
aaa authentication login default line
aaa authentication login radius-logins group radius line
enable secret 5
clock timezone CENTRAL -6
clock summer-time CENTRAL_DST recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
ip subnet-zero
no ip domain-lookup
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
switchport access vlan 129
switchport mode access
no ip address
duplex full
speed 100
spanning-tree portfast
interface FastEthernet0/2
no ip address
duplex full
speed 100
interface FastEthernet0/3
no ip address
duplex full
speed 100
interface FastEthernet0/4
no ip address
duplex full
speed 100
interface FastEthernet0/5
no ip address
duplex full
speed 100
interface FastEthernet0/6
no ip address
duplex full
speed 100
interface FastEthernet0/7
no ip address
duplex full
speed 100
interface FastEthernet0/8
no ip address
duplex full
speed 100
interface FastEthernet0/9
no ip address
duplex full
speed 100
interface FastEthernet0/10
no ip address
duplex full
speed 100
interface FastEthernet0/11
no ip address
duplex full
speed 100
interface FastEthernet0/12
no ip address
duplex full
speed 100
interface FastEthernet0/13
no ip address
duplex half
speed 10
interface FastEthernet0/14
no ip address
duplex full
speed 100
interface FastEthernet0/15
no ip address
duplex full
speed 100
interface FastEthernet0/16
no ip address
duplex full
speed 100
interface FastEthernet0/17
no ip address
duplex full
speed 100
interface FastEthernet0/18
no ip address
interface FastEthernet0/19
no ip address
interface FastEthernet0/20
no ip address
interface FastEthernet0/21
no ip address
interface FastEthernet0/22
no ip address
interface FastEthernet0/23
no ip address
interface FastEthernet0/24
no ip address
interface FastEthernet0/25
no ip address
interface FastEthernet0/26
no ip address
interface FastEthernet0/27
no ip address
duplex full
speed 100
interface FastEthernet0/28
no ip address
interface FastEthernet0/29
no ip address
interface FastEthernet0/30
no ip address
interface FastEthernet0/31
description video monitoring pharm
no ip address
interface FastEthernet0/32
no ip address
interface FastEthernet0/33
no ip address
interface FastEthernet0/34
no ip address
interface FastEthernet0/35
no ip address
interface FastEthernet0/36
no ip address
interface FastEthernet0/37
no ip address
interface FastEthernet0/38
no ip address
interface FastEthernet0/39
no ip address
interface FastEthernet0/40
no ip address
interface FastEthernet0/41
no ip address
interface FastEthernet0/42
no ip address
interface FastEthernet0/43
no ip address
interface FastEthernet0/44
no ip address
interface FastEthernet0/45
no ip address
interface FastEthernet0/46
no ip address
interface FastEthernet0/47
switchport access vlan 404
no ip address
interface FastEthernet0/48
description Network UPS
switchport access vlan 500
no ip address
duplex half
speed 10
interface GigabitEthernet0/1
switchport trunk native vlan 500
switchport trunk allowed vlan 129,404,500
switchport mode trunk
switchport nonegotiate
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan500
ip address 172.18.77.18 255.255.255.0
no ip route-cache
ip default-gateway 172.18.77.1
no ip http server
Here is the ouput of the 3560: (NOT WORKING)
c3560g#sh run
Current configuration : 9275 bytes
version 12.2
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
hostname c3560g
enable secret 5
aaa new-model
aaa session-id common
clock timezone CST -6
clock summer-time CDT recurring
system mtu routing 1500
ip subnet-zero
no ip domain-lookup
no file verify auto
vlan internal allocation policy ascending
speed 100
duplex full
speed 100
duplex full
interface GigabitEthernet0/3
speed 100
duplex full
interface GigabitEthernet0/4
speed 100
duplex full
interface GigabitEthernet0/5
speed 100
duplex full
interface GigabitEthernet0/6
speed 100
duplex full
interface GigabitEthernet0/7
speed 100
duplex full
interface GigabitEthernet0/8
speed 100
duplex full
interface GigabitEthernet0/9
speed 100
duplex full
interface GigabitEthernet0/10
speed 100
duplex full
interface GigabitEthernet0/11
speed 100
duplex full
interface GigabitEthernet0/12
speed 100
duplex full
interface GigabitEthernet0/13
speed 10
duplex half
interface GigabitEthernet0/14
speed 100
duplex full
interface GigabitEthernet0/15
speed 100
duplex full
interface GigabitEthernet0/16
speed 100
duplex full
interface GigabitEthernet0/17
speed 100
duplex full
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
description special video monitoring pharmacy
interface GigabitEthernet0/32
shutdown
interface GigabitEthernet0/33
shutdown
interface GigabitEthernet0/34
interface GigabitEthernet0/35
shutdown
interface GigabitEthernet0/36
shutdown
interface GigabitEthernet0/37
shutdown
interface GigabitEthernet0/38
interface GigabitEthernet0/39
shutdown
interface GigabitEthernet0/40
shutdown
interface GigabitEthernet0/41
shutdown
interface GigabitEthernet0/42
shutdown
interface GigabitEthernet0/43
interface GigabitEthernet0/44
shutdown
interface GigabitEthernet0/45
shutdown
interface GigabitEthernet0/46
description ap-craniofacial
switchport access vlan 701
interface GigabitEthernet0/47
description privprac-WHC
interface GigabitEthernet0/48
interface GigabitEthernet0/49
description dista
interface GigabitEthernet0/50
description cat2950b
interface GigabitEthernet0/51
interface GigabitEthernet0/52
interface Vlan1
no ip address
shutdown
interface Vlan500
no ip route-cache
ip classless
no ip http server
l
can you try clearing the arp cach on the ASA.
Alain.
