Community Member
ASA 5505 Interface Communication
I have configured our ASA with an interface for the internal network (BeneNetwork) and our wireless solution (WLAN) everything is working OK the wireless clients receive all configurations from DHCP and can ping the the gateway address., but does not have communication to BeneNetwork.
Attached is my configuration for review,
Thank you,
ASA Version 8.2(2)
hostname remote
domain-name benetech.org
enable password sh3Lt8bNBi5BmLfG encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 172.16.20.100 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address xxx.xxx.xxx.xxx 255.255.255.240
interface Vlan3
description WLAN
nameif WLAN
security-level 100
ip address 172.16.30.100 255.255.255.0
interface Vlan4
description Benetech Network
nameif BeneNetwork
security-level 100
ip address 10.10.220.100 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 4
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
switchport access vlan 3
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu WLAN 1500
mtu BeneNetwork 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any BeneNetwork
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (WLAN) 1 0.0.0.0 0.0.0.0
nat (BeneNetwork) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 10.10.220.23
dhcpd domain benetech.local
dhcpd auto_config outside
dhcpd option 3 ip 172.16.30.100
dhcpd address 172.16.30.150-172.16.30.200 WLAN
dhcpd enable WLAN
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:c40d69de4ce1b0e912f403ec6902c2b2
: end
2 ACCEPTED SOLUTIONS
Re: ASA 5505 Interface Communication
Stephen,
Could you please try this:
static (inside,inside) 10.10.220.0 10.10.220.0 netmask 255.255.255.0
Federico.
Stephen,
I'm very glad to hear that is working now.
Please rate the post if you find it helpful (this was the longest one I remembered ;-))
Federico.
Stephen,
Add the following command to test the communication between the WLAN and Benetech network.
static (WLAN,Benetech) 172.16.30.0 172.16.30.0 netmask 255.255.255.0
There's no need for ACLs since both interfaces have the same security level.
Federico.
Community Member
I used this static (WLAN,BeneNetwork) 172.16.30.0 172.16.30.0 netmask 255.255.255.0 with no success.
Before I make any changes should this be formatted as static (WLAN,BeneNetwork) 172.16.30.0 10.10.220.0 netmask 255.255.255.0
Stephen,
You should not change the static.
Can you please verify that the devices on the 172.16.30.0/24 and 10.10.220.100/24 have their default gateway the ASA?
172.16.30.100 and 10.10.200.100
Federico.
Community Member
All devices on the 10.10.220.0 network is using another device for gateway the address is 10.10.220.101 both devices are connected to the same LAN segment.  I can ping 10.10.220.100 from BeneNetwork but not from WLAN.
The WLAN clients are using 172.16.30.100 for their gateway.
Stephen,
The 10.10.220.101 device is a router?
This device should have a route to 172.16.30.0/24 pointing to the 10.10.220.100 (ASA), or a default gateway pointing to the ASA.
Please confirm this.
Federico.
Community Member
its another asa they wanted to separated the devices, i will try the route.  is this so the 10.10.220.0 network knows where to return communication?
Exactly.
Federico.
Community Member
heres what i put in the other asa route 172.16.30.0 255.255.255.0 10.10.220.100 1
still having issues
The Wireless clients have 172.16.30.100 as their default gateway.
The Benetech clients have 10.10.220.101 as their default gateway, but you added a route to the WLAN to 10.10.220.100
So, the routing is correct.
You also have this command:
So, the WLAN clients will not be NATed when talking to the Benetech devices.
You have the:
To allow communication between interfaces with the same security level (as this is the case)
One good test that you can do is the following:
If you have access to the GUI interface, perform a Packet Tracer test, it will show exactly where is the communication failing.
You can do this from the CLI as well with the packet-tracer command.
Another important thing:
Since 10.10.200.101 is another ASA (you need to make sure that on that ASA, this communication is permitted)
Federico.
Community Member
From the ASA with the WLAN attached from cli I can
ping any node on the benetech network I.E. (10.10.220.23) from the WLAN clients I can ping 172.16.30.100 but not the inside interface or the benetech interface which is a port on the same device.
I will try a packet-tracer and see what I receive.
Stephen,
From what you mentioned its already working.
The ASAs have this rule:
You can only PING the interface of the ASA which is where traffic is coming from.
This means that the WLAN clients can only PING the WLAN interface.
The Benetech clients can only PING the Benetech interface.
You can never PING any other interface of the ASA (besides the interface where the traffic goes into).
Try the communication between devices on the interfaces and make sure they work.
Otherwise let's take a look at the Packet Tracer.
Federico.
Community Member
Sir, here is the error I am receiving:
Asymmetric NAT rules matched for forward and reverse flows; Connection for udp src WLAN:172.16.30.167/63541 dst BeneNetwork:10.10.220.23/53 denied due to NAT reverse path failure
This happens when the return path of the connection is not the same path that the request.
Asymmetric connections are not supported on the ASA. Let's see why you're getting an asymmetric behavior...
Could you post a simple drawing of your topology to understand it better?
Federico.
Community Member
Our ASA .101 interface 0/0 is the outside interface, 0/4 is the inside interface and addressed 10.10.220.101 all nodes on the benetech network connect to this device with the gateway for the clients set at 10.10.220.101.
ASA .100 interface 0/0 is the outside interface, 0/1 is the benetech network and connected directly to the switch just as the other ASA, 0/6,7 is the WLAN interface with the clients gateway set at 172.16.30.100,
Community Member
I took out the nat (beneNetwork) 1 0.0.0.0 0.0.0.0 and now not getting the error
Community Member
After some changes here is what I am receiving:
Built inbound UDP connection 4325 for WLAN:172.16.30.171/53558 (172.16.30.171/53558) to BeneNetwork:10.10.220.23/53 (10.10.220.23/53)
Teardown UDP connection 4271 for WLAN:172.16.30.171/62768 to BeneNetwork:10.10.220.23/53 duration 0:02:03 bytes 76
Community Member
Community Member
Packet Tracer Results
Result:
input-interface: WLAN
input-status: up
input-line-status: up
output-interface: NP Identity Ifc
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Result:
input-interface: BeneNetwork
input-status: up
output-status: up
Action: drop
Stephen,
There seems to be an ACL dropping the packets (which I don't see from your original configuration).
Can you post:
sh run access-list
sh run access-group
Federico.
Community Member
Yes I found out that the ASA has a built-in implicit rule which deny's all traffic, you then need to create ACL's to create passage past the implicit rule.  I am having trouble doing this.  Any suggestions?
This what I get with the sh run access-list, the sh run access-group returns nothing.
access-list WLAN_nat0_outbound extended permit ip any any
Thank you  Sir,
Stephen
Stephen,
In theory since you have both interfaces we are dealing with, configured with the same security level (level 100), there's no need for an ACL to permit the traffic to flow.
However, the packet-tracer seems to report an ACL dropping problem.
What if you enable ACLs to permit the traffic.
i.e.
access-list WLAN permit ip any any
access-list Benetech permit ip any any
access-group WLAN in interface WLAN
access-group Benetech in interface Benetech
Obviously, the above ACLs are a security gap, I just want to see if by permitting all traffic explicity with the ACLs, we get a different result from the packet tracer.
Federico.
Community Member
I added the lines you suggested IP packets are still being droped
here is my current configuration:
ASA Version 8.2(2)
hostname remote
names
interface Vlan2
nameif outside
security-level 0
ip address 66.201.46.94 255.255.255.240
interface Vlan3
description WLAN
nameif WLAN
security-level 100
interface Vlan4
nameif BeneNetwork
security-level 100
ftp mode passive
access-list WLAN extended permit ip any any
access-list BeneNetwork extended permit ip any any
pager lines 24
logging enable
mtu outside 1500
mtu WLAN 1500
no failover
icmp permit any WLAN
arp timeout 14400
nat (WLAN) 0 access-list WLAN_nat0_outbound
access-group BeneNetwork in interface BeneNetwork
route outside 0.0.0.0 0.0.0.0 66.201.46.81 1
http server enable
http 10.10.220.0 255.255.255.0 BeneNetwork
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable WLAN
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:b63aa441f064846d661588820dfdb228
Community Member
here is the result of a packet trace:
packet-tracer input WLAN tcp 172.16.30.100 53 10.10.220.23 53
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.10.220.0     255.255.255.0   BeneNetwork
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Forward Flow based lookup yields rule:
in  id=0xd8a8b300, priority=500, domain=permit, deny=true
        hits=4, user_data=0x6, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip=172.16.30.100, mask=255.255.255.255, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Result:
input-status: up
output-interface: BeneNetwork
output-status: up
Action: drop
Stephen,
I would do this:
interface Vlan4
security level 99
no access-list WLAN_nat0_outbound extended permit ip any any
no nat (WLAN) 0 access-list WLAN_nat0_outbound
no nat (WLAN) 1 0.0.0.0 0.0.0.0
With the changes above, we're going to have only this configuration:
interface Vlan3
description WLAN
nameif WLAN
security-level 100
interface Vlan4
nameif BeneNetwork
security-level 99
Try communication between the networks.
Federico.
Community Member
Still having dropped packets, from the wireless client I can ping the gateway IP address 172.16.30.100 but not anything past there.
Post this commands after the last changes:
sh run int vlan 3
sh run int vlan 4
sh run nat
sh run static
sh run global
sh run access-list
sh run access-group
Federico.
Community Member
Thank you for your help with this issue, here what you have requested.
interface Vlan3
description WLAN
nameif WLAN
security-level 100
interface Vlan4
nameif BeneNetwork
security-level 99
sh run nat – returns nothing
Ok,
You should be able from a device off the WLAN interface to communicate with a device off the Benetech interface.
If it does not work, let me know the source IP and the destination IP of the connection you're trying.
Federico.
Community Member
No I cannot, the IP of the laptop is 172.16.30.190 the IP I am attempting to connect to is 10.10.220.23.  I can ping the gateway 172.16.30.100 but not anything else past this IP.
5924
