Community Member
ASA 5505 Network Configuration & Telephony problem
Hi everyone,
We would like to use a cisco asa 5505 to replace our pfsense.
Please find in attachement the architecture we want :
Could you tell me if the configuration below is OK?
Because with this configuration we have the following problems:  we are using Astra phones and Avaya phones and it seems that there is communication problems when we tried to call an avaya with an astra. (Users who are using Avaya cannot hear Astra users)
With pfsenses we don't have this problem.
Maybe my NAT is not correctly configured?
Thank you for your responses.
ASA Version 8.2(5)
hostname rasamaurice
names
interface Ethernet0/0
interface Ethernet0/1
switchport access vlan 2
interface Ethernet0/2
switchport access vlan 3
interface Ethernet0/3
switchport access vlan 4
interface Ethernet0/4
switchport access vlan 5
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
interface Vlan1
nameif inside
security-level 0
ip address 192.168.22.254 255.255.255.0
interface Vlan2
nameif wan
security-level 0
ip address 192.168.100.254 255.255.255.0
interface Vlan3
nameif lan
security-level 100
ip address 192.168.1.10 255.255.255.0
interface Vlan4
nameif lan_mail
security-level 0
ip address 192.168.66.254 255.255.255.0
interface Vlan5
nameif wan2
security-level 0
ip address 192.168.200.1 255.255.255.0
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group icmp-type DefaultICMP
description DefaultICMP Types permitted
icmp-object echo-reply
icmp-object unreachable
icmp-object time-exceeded
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object udp
protocol-object tcp
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list lan_access_in extended permit ip any any
access-list inside_access_in extended permit ip any any
access-list wan2_access_in extended permit ip any any
access-list lan_mail_access_in extended permit ip any any
access-list wan_access_in extended permit ip any any
access-list from_outside extended permit icmp any any echo
access-list name extended permit icmp any interface inside
pager lines 24
mtu inside 1500
mtu wan 1500
mtu lan 1500
mtu lan_mail 1500
mtu wan2 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (network) 11 interface
global (wan) 11 interface
global (inside) 1 interface
global (lan_mail) 11 interface
global (wan2) 11 interface
nat (network) 11 192.168.22.0 255.255.255.0
nat (network) 11 0.0.0.0 0.0.0.0
access-group inside_access_in in interface inside
access-group wan_access_in in interface wan
access-group lan_access_in in interface lan
access-group lan_mail_access_in in interface lan_mail
access-group wan2_access_in in interface wan2
route wan 0.0.0.0 0.0.0.0 192.168.100.1 1
route lan 10.0.0.0 255.0.0.0 192.168.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
http server enable
http 192.168.22.0 255.255.255.0 inside
http 10.0.0.0 255.0.0.0 lan
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh 192.168.22.0 255.255.255.0 inside
ssh 10.0.0.0 255.0.0.0 lan
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username admin password I54YI.lNurijhj50 encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Athoseb
148
