09-04-2013 01:18 PM - edited 03-07-2019 03:18 PM
I have an ASA 5505, I enable ports 6 and 7. Configured auto for speed and duplex. I cannot get the ports on.
The device is AXIS T8129 PoE extender and the compliant standards are the following:
IEEE 802.3af, IEEE 802.3at
The extebder should be compliant with the ASA.
#sh power inline
Interface Power Device
Et0/0 n/a n/a
Et0/1 n/a n/a
Et0/2 n/a n/a
Et0/3 n/a n/a
Et0/4 n/a n/a
Et0/5 n/a n/a
Et0/6 Off n/a
Et0/7 Off n/a
Thanks in advance,
Bobby
Solved! Go to Solution.
09-04-2013 02:18 PM
Et0/6 Off n/a
Et0/7 Off n/a
Did you no shut these 2 ports which are the only ones supporting PoE ?
Alain
09-04-2013 02:18 PM
Et0/6 Off n/a
Et0/7 Off n/a
Alain
09-04-2013 03:01 PM
I did do the no shut command.
I think it is the devices themselves because I grabbed an IP phone and instantly the port supplied PoE.
I probably need to close this post
09-04-2013 03:40 PM
Actually I found out you have to run LLDP on a switch since it is a non-cisco device. Can you run LLDP on a ASA 5505?
