Webcast-Catalyst9k
ASA 5505 POE
I have an ASA 5505, I enable ports 6 and 7. Configured auto for speed and duplex. I cannot get the ports on.
The device is AXIS T8129 PoE extender and the compliant standards are the following:
IEEE 802.3af, IEEE 802.3at
The extebder should be compliant with the ASA.
#sh power inline
Interface   Power   Device
Et0/0        n/a    n/a
Et0/1        n/a    n/a
Et0/2        n/a    n/a
Et0/3        n/a    n/a
Et0/4        n/a    n/a
Et0/5        n/a    n/a
Et0/6        Off    n/a
Et0/7        Off    n/a
Thanks in advance,
Bobby
1 ACCEPTED SOLUTION
Purple
ASA 5505 POE
Et0/6        Off    n/a
Et0/7        Off    n/a
Did you no shut these 2 ports which are the only ones supporting PoE  ?
Alain
Purple
ASA 5505 POE
Et0/6        Off    n/a
Et0/7        Off    n/a
Alain
ASA 5505 POE
I did do the no shut command.
I think it is the devices themselves because I grabbed an IP phone and instantly the port supplied PoE.
I probably need to close this post
ASA 5505 POE
Actually I found out you have to run LLDP on a switch since it is a non-cisco device. Can you run LLDP on a ASA 5505?
276
