ASA 5510 NAT Problems
mebernstein
Problem:
I am currently trying to configure NAT on my ASA 5510. I am having problems geting the two interfaces to comunicate with each other. I can ping my Linksys Router from the outside interface of the firewall, but I am unable to do this from the inside interface.
Setup:
I currently have a Linksys RV082 connected to two ISP's, connected on the LAN side of that is a Cisco ASA 5510 firewall, connected on the lan side of that is a Cisco 2821 router.
NAT:
Original:
Interface: interior
Source Network: interior:any/0
Destination Network: any
Translated:
Interface: Exterior
Address: interface PAT
Static routes:
Linksys to Firewall:
Destination IP: 192.168.6.0
Subnet mask: 255.255.255.0
Default Gateway: 192.168.0.101
Hop count: 1
Interface: lan
Firewall to Linksys
Exterior 0.0.0.0 0.0.0.0 192.168.0.1 1
IP Addresses:
Inside firewall: 192.168.6.0
Outside firewall: 192.168.0.101
Linksys: 192.168.0.1
Cisco Router Outside: 192.168.6.101
Cisco Router Inside: 192.168.4.0
____________Cisco ASA 5510 Configuration_____________________________
Firewall# show running-config
: Saved
ASA Version 7.0(8)
hostname Firewall
domain-name default.domain.invalid
enable password 6efABQ2cPmP7OKuA encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
dns-guard
interface Ethernet0/0
nameif Interior
security-level 20
ip address 192.168.6.1 255.255.255.0
interface Ethernet0/1
nameif Exterior
security-level 20
ip address dhcp setroute
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
same-security-traffic permit inter-interface
pager lines 24
logging asdm informational
mtu management 1500
mtu Exterior 1500
mtu Interior 1500
asdm image disk0:/asdm-508.bin
no asdm history enable
arp timeout 14400
global (Exterior) 100 interface
nat (Interior) 100 0.0.0.0 0.0.0.0
route Exterior 0.0.0.0 0.0.0.0 192.168.0.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sysopt noproxyarp Exterior
sysopt noproxyarp Interior
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd address 192.168.6.2-192.168.6.10 Interior
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd enable management
dhcpd enable Interior
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
Cryptochecksum:ff820992c3c5d0aa4866e518fe0f9766
: end
5 Replies 5
John Blakley
If you're wanting to ping from inside out, you should put inspect icmp under your policy-map:
inspect icmp
That should work.
HTH,
John
HTH, John *** Please rate all useful posts ***
Still Does not work any reason?
Hi Michael again,(grin)
Your NAT statements look fine to me. Doing PAT. Right? Please let me know about your security policies from inside to outside. I haven't seen any ACL on your configuration. You can use ASDM to see what's going on.
Edit: As john mentioned. For ICMP(Stateless), you need to inspect it or allow echo-reply back from outside to inside.
Toshi
What do ACL's do? Do I need them?
Here is where I am, I am DEAD stuck. I can not get trafic of any kind to pass through the ASA 5510. I have tried what I beleive to be everything. Below I have posted my new configuration file. I need to know what is wrong with it and how to fix it. I have also cut the 2821 out of the equation so now the computer is connected directly to the asa 5510. Before this all came about I did have the Linksys and the 2821 communicating, I also have heard that you can put the asa 5510 in the middle in transparent mode (not routed) and keep the packet flow the way it was before. Any help is greatly appreciated.
Cisco ASA 5510 configuration:
ASA Version 7.0(8)
hostname Firewall
names
dns-guard
nameif Interior
security-level 100
nameif Exterior
security-level 0
shutdown
nameif 0
security-level 0
no ip address
nameif management
security-level 100
management-only
ftp mode passive
access-list Exterior_access_in extended permit tcp interface Exterior interface Interior
access-list Exterior_access_in extended permit icmp interface Exterior interface Interior
access-list Exterior_access_in extended permit ip interface Exterior interface Interior
access-list Exterior_access_out extended permit tcp interface Interior interface Exterior
access-list Exterior_access_out extended permit icmp interface Interior interface Exterior
access-list Exterior_access_out extended permit ip interface Interior interface Exterior
access-list Interior_access_in extended permit tcp interface Interior interface Exterior
access-list Interior_access_in extended permit icmp interface Interior interface Exterior
access-list Interior_access_in extended permit ip interface Interior interface Exterior
access-list Interior_access_out extended permit tcp interface Exterior interface Interior
access-list Interior_access_out extended permit icmp interface Exterior interface Interior
access-list Interior_access_out extended permit ip interface Exterior interface Interior
access-list 0_access_in extended permit tcp any interface Exterior
pager lines 24
mtu management 1500
mtu Exterior 1500
mtu Interior 1500
mtu 0 1500
icmp permit any management
icmp permit any Exterior
icmp permit any Interior
arp timeout 14400
global (Interior) 101 192.168.6.2-192.168.6.10
nat (Interior) 100 0.0.0.0 0.0.0.0 dns
nat (Interior) 100 0.0.0.0 0.0.0.0 outside
access-group Exterior_access_in in interface Exterior per-user-override
access-group Exterior_access_out out interface Exterior
access-group Interior_access_in in interface Interior per-user-override
access-group Interior_access_out out interface Interior
access-group 0_access_in in interface 0
http server enable
sysopt noproxyarp 0
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd auto_config Interior
Cryptochecksum:..
