Community Member
ASA 5510 Routing Problems
Problem & setup:
My current configuration is a Linksys RV082 dual-wan router connected to a Cisco ASA 5510. Connected to a Cisco 2821 Router. Right now I can not even get the Firewall(ASA 5510) and the Linksys to communicate.
Static routes:
Linksys to Firewall:
Destination IP:
Subnet mask:
Default Gateway:
Hop count: 1
Interface: lan
Firewall to Linksys
Cant get this to work?
The firewall says "
[ERROR] route Interior 1
Cannot add route entry, possible conflict with existing routes" When I am trying to configure
Interface Name: Inside
IP address:
Gateway IP:
(at the bottom I get an option of "Tunneled(used only for default route)" or Metric 1)
IP Addresses:
Inside firewall:
Outside firewall:
Cisco Router Outside:
Cisco Router Inside:
____________Cisco ASA 5510 Configuration_____________________________
Firewall# show running-config
: Saved
ASA Version 7.0(8)
hostname Firewall
domain-name default.domain.invalid
enable password 6efABQ2cPmP7OKuA encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
interface Ethernet0/0
nameif Interior
security-level 20
ip address
interface Ethernet0/1
nameif Exterior
security-level 20
ip address dhcp setroute
interface Ethernet0/2
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address
ftp mode passive
same-security-traffic permit inter-interface
pager lines 24
logging asdm informational
mtu management 1500
mtu Exterior 1500
mtu Interior 1500
asdm image disk0:/asdm-508.bin
no asdm history enable
arp timeout 14400
global (Exterior) 100 interface
nat (Interior) 0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sysopt noproxyarp Exterior
sysopt noproxyarp Interior
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address management
dhcpd address Interior
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd enable management
dhcpd enable Interior
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
: end
Thank You,
Re: ASA 5510 Routing Problems
First of all, You have to make sure that the ip address of Exterior is
nameif Exterior
security-level 20
ip address ip address
After that you should do things as follows:
route Exterior 1
Edit: What do you want to do with NAT statements you configured? It's not clear to me.(grin)
Community Member
It is not realy what I was trying to do, it was more or less of what I thought I was supposed to do. It was my interpretation that you had to NAT information that went from router to router. What would you do? Also what would be some of the routes on some of the other equiptment?
Thank You,
