ASA: Can you exclude IP from a DHCP range?
Quick question, ran into this tonight. Are you able to tell the ASA to exclude certain IPs within the DHCP range from being assigned via DHCP?
For instance my DHCP range is 192.168.2.100 - 192.168.2.174
well we have a couple of server at 192.168.2.100 and 192.168.2.117, can I tell the ASA not to hand out those 2 IPs?
1 ACCEPTED SOLUTION
Re: ASA: Can you exclude IP from a DHCP range?
I think the only way to exclude them is not to include them in the DHCP range at all. For example, you should create a DHCP range of 192.168.2.120 - 192.168.2.174.
Dandy
Dandy
That is what I was afraid of...thx for the reply.
401
