Webcast-Catalyst9k
ASA not routing internally
Please help
my ASA is not routing internal routes on the same VLAN
ASA 10.202.69.1
2811(Router)  10.202.69.31   connects to 10.202.200.0  remote network
Users: 10.202.69.0/24
users default gateway is ASA
i need to forward 10.202.200.0 network on ASA to cisco 2811
i have added the following commands on ASA
same-security-traffic permit intra-interface
route inside 10.202.192.0 255.255.192.0 10.202.69.31 1
ping from ASA works but from users pc NO
can you please help
please find ASA show run attached
Everyone's tags (4)
1 ACCEPTED SOLUTION
Purple
ASA 10.202.69.1
2811  10.202.69.31    has 10.202.200.0 network
users are on the 10.202.200.0 network ? if so how can they arp for their default gateway which is not on the same subnet ?
Alain
Please post your ASA's log here to be more accurate.
Oscar
what debugs would you like me to run
Purple
ASA 10.202.69.1
Alain
users have their gateway ASA 10.202.69.1 ... users are on 10.202.69.0/24 trying to access 10.202.200.0/24
Purple
Can you do a packet-tracer on the ASA and paste output
packet-tracer input inside icmp 10.202.69.200 8 0 10.202.200.20 detailed
packet-tracer input inside icmp 10.202.200.20 0 0 10.202.69.200 detailed
Alain
148
