Community Member
ASA5505 displays 0 length in disk0
Hello All I've upgraded the IOS on this device from 7 to 8 with ROMMON, had to erase disk0 do to so now flash shows absolutely no length with 2 items listed. 0 bytes total (0 bytes free)
Hall of Fame Super Gold
Re: ASA5505 displays 0 length in disk0
Norm
I have not been through the upgrade of code with ROMMON so do not have experience to guide you. But it would seem logical that at this point you should copy the image files back onto disk0. If you use the fsck command on disk0 and on flash does it report anything?
Rick
Community Member
Hi Rick fsck disk0 reports unsupported file system type
Norm
Have you tried format disk0?
Rick
Community Member
Hi Rick
Format disk0 did work to bring it back.
Thanks for the help
Norm
I am glad that you got it resolved. Thanks for posting back and indicating that the format did help.
Rick
412
