ASA5505: Inbound FTP "ignored"
I have an FTP server on inside interface, IP 10.10.40.40.
I have created the following rules to allow ftp and ftp-data inbound externally:
static (inside,outside) tcp interface ftp 10.10.40.40 ftp netmask 255.255.255.255
static (inside,outside) tcp interface ftp-data 10.10.40.40 ftp-data netmask 255.255.255.255
access-list outside_access_in extended permit tcp any host 10.10.40.40 eq ftp log disable
access-list outside_access_in extended permit tcp any host 10.10.40.40 eq ftp-data log disable
However, all attempts at inbound FTP fail. Full config is below:
ASA Version 8.2(5)
hostname ASA5505
names
interface Ethernet0/0
 description to_ISP
 switchport access vlan 200
interface Vlan10
 description inside-interface
 nameif inside
 security-level 100
 ip address 10.10.10.1 255.255.255.252
interface Vlan200
 description outside-interface
 nameif outside
 security-level 0
 pppoe client vpdn group BT
 ip address 255.255.255.255 pppoe setroute
ftp mode passive
clock timezone GMT/BST 0
clock summer-time GMT/BDT recurring last Sun Mar 1:00 last Sun Oct 2:00
object-group network NAS
access-list outside_access_in extended permit icmp any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu dmz 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any dmz
icmp permit any echo dmz
icmp deny any echo-reply outside
icmp permit any outside
icmp permit any echo outside
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 10.10.10.0 255.255.255.0
nat (inside) 1 10.10.20.0 255.255.255.0
nat (inside) 1 10.10.30.0 255.255.255.0
nat (inside) 1 10.10.40.0 255.255.255.0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 80.x.x.x 1
route inside 10.10.10.0 255.255.255.0 10.10.10.1 1
route inside 10.10.20.0 255.255.255.0 10.10.10.1 1
route inside 10.10.30.0 255.255.255.0 10.10.10.1 1
route inside 10.10.40.0 255.255.255.0 10.10.10.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
http server enable
http 10.0.0.0 255.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet 10.0.0.0 255.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group BT request dialout pppoe
vpdn group BT localname
vpdn group BT ppp authentication chap
vpdn username password ***** store-local
threat-detection basic-threat
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect pptp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:aecb9042a375f6fa1a7c6a0d6489aed2
: end
24
