Webcast-Catalyst9k
Bronze
ASR 1001 False environmental alert
I have a few new ASR 1001s throwing false environmental alerts.
According to the logs, the inlet temp is in excess of 100 degrees C.
When I telnet to the routers, they're well within tolerance (30-32C)
Running 15.1(1)S and bug toolkit shows no related issues or caveats.
Has anyone seen this?
Ven
Ven Taylor
1 REPLY
Bronze
Re: ASR 1001 False environmental alert
Spoke to TAC about this.  Turns out it is a cosmetic bug.
CSCtr38540
1RU PS: False temperature readings on ASR power supplies
Externally found moderate (Sev3) bug: W-Wait
Here is the release-note of the bug:
Symptom:
ASR reports false temperature readings from the power supply similar to the following -
%ENVIRONMENTAL-1-ALERT: Temp: Inlet, Location: P1, State: Shutdown,Reading: 127 Celsius
Conditions:
This has only been seen on the ASR.
Workaround:
None.  No functional impact has been observed from these messages.
This is a cosmetic bug, currently under investigation. There is no service impact with this bug.
Ven
Ven Taylor
1569
