ASR 1002 error message :%IOSXE-4-PLATFORM: R0/0: kernel: mcp: hrtimer_get_softirq_time() not serviced
ccnarick
Hi ,
I got an error message in ASR 1002.
The ASR information:
(1)#show version
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 12.2(33)XNF1, RELEASE SOFTWARE (fc1)
System image file is "bootflash:packages.conf"
Last reload reason: PowerOn
(2)#show redundancy states
       my state = 13 -ACTIVE
     peer state = 8  -STANDBY HOT
           Mode = Duplex
           Unit = Primary
        Unit ID = 48
Redundancy Mode (Operational) = sso
Redundancy Mode (Configured)  = sso
Redundancy State              = sso
     Maintenance Mode = Disabled
    Manual Swact = enabled
Communications = Up
   client count = 75
client_notification_TMR = 30000 milliseconds
           RF debug mask = 0x0
(3)#show platform
Chassis type: ASR1002
Slot      Type                State                 Insert time (ago)
0         ASR1002-SIP10       ok                    12w2d
0/0      4XGE-BUILT-IN       ok                    12w2d
R0        ASR1002-RP1         ok                    12w2d
R0/0                         ok, active            12w2d
R0/1                         ok, standby           12w2d
F0        ASR1000-ESP10       ok, active            12w2d
P0        ASR1002-PWR-AC      ok                    12w2d
P1        ASR1002-PWR-AC      ok                    12w2d
Slot      CPLD Version        Firmware Version
0         07120202            12.2(33r)XNC
R0        08011017            12.2(33r)XNC
Giuseppe Larosa
Hello Rick,
have you received this error only once or multiple times?
the error comes from kernel of OS running on active route processor ( R0/0) and states that a routine hasn't been serviced.
The affected routine is named hrtimer_get_softirq_time() and the name leads to a control process that should get the timestamp of execution of software based interrupts.
Have you experienced any noticeable issue?
Hope to help
Giuseppe
Hi Giuseppe,
I have two ASR1002 routers.And I got the message twice every device.
I haven't experienced any noticeable issue or other errors.
Do you recommand ?
Rick
Hello Rick,
if it happened only twice on two boxes I would think of a possible SW bug
For the moment I would investigate on bug toolkit and/or I would open a TAC service request.
However, if no real issues the bug may be cosmetic
Hope to help
Giuseppe
Thank you very much !!
I wii open a TAC case.
If any news,I will update to here.
rick
