ASR1002 Interface LIIN0
On my
Cisco IOS Software, IOS-XE Software  (PPC_LINUX_IOSD-ADVENTERPRISEK9-M),
Version 12.2(33)XNB1, RELEASE SOFTWARE (fc1)
cisco ASR1002 (RP1) processor with 1770812K/6147K bytes of memory.
8 FastEthernet interfaces
4 Gigabit Ethernet interfaces
I see a new interface object
- .1.3.6.1.2.1.2.2.1.2.14 = STRING: "LIIN0"
Anyone know what LIIN0 stands for?
1 ACCEPTED SOLUTION
Re: ASR1002 Interface LIIN0
This shows up as per bug ID CSCsu77188. 12.2(33)XNC or later will have this fixed.
LIIN0 is interface used for internal VRF.
Interface LIIN0 (LIIN = Linux-IOS Internal Network)
It's not affect to the box and this can be ignored.
HTH,
jerry
HTH,
jerry
thx for the info. i have downloaded 122-33.XNE2. will see if that fixes the issue.
774
