ASR9000/XR: Loadbalancing. ARM Router IDs question.
Hi all, The bundle-ethernet hash calculations in IOX includes the router-id to provide some per node variation. As explained in the post: https://supportforums.cisco.com/docs/DOC-26687
I have two different routers that MUST have the exact same hash, so the only way I found to acomplish that is to configure the same loopback interface in both routers. Is there a way to set the ARM Router IDs without configuring loopbacks interfaces? Or is there a way to ignore the router-ids from the hash calculation?
The problem is that in order to have the same router-id I have to restart the routers, and then I have to exclude the loopbacks from the IGP and LDP. Also, the configuration looks like a workaround... :-)
Thanks!
Mariano
Everyone's tags (3)
115
