09-02-2013 10:32 PM - edited 03-07-2019 03:16 PM
I have 4506e switch and configured DHCP pool.
But for two PCs which I have connected to core switch need to assign specific IP address through DHCP only.
How can I achieve this?
Solved! Go to Solution.
09-02-2013 10:43 PM
Hi Vishal,
You can try DHCP binding, where in you bind the MAC address of the PC to one specific ip address on the DHCP pool. Please go through below url and look under heading "Setting Mannual Binding"
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a00800f0804.shtml
Hope that helps.
Najaf
09-02-2013 10:43 PM
Hi Vishal,
Hope that helps.
Najaf
09-03-2013 01:40 AM
Thanks Najaf.. It worked
09-03-2013 02:41 AM
Hi Vishal,
Glad that it is working as expected:-)
Please mark the post as answered which will then helps other users with similar issue to find proper resolution.
Najaf
09-03-2013 01:47 AM
Najaf,
That's a very nice document! Thanks!
Best regards,
Peter
09-03-2013 02:37 AM
Thanks Peter for the Endorsment.
Really apprciate this.
Najaf
