Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Assistance with which switches/routers to use?
I am in the process of designing a network.
The main building has two floors, so does the second and third building.
I have in my main building 1st floor 49 users, main building second floor 43.
Building 2 first floor 33 users, building 2 second floor 33 users.
Building 3 first floor 31 users, building 3 second floor 33 users.
I intend to use seperate switches on each floor in building 2 and 3 with routers. I also plan to use a fiber backbone on each floor from the main building.
I have looked at the Cisco's web site but I am a bit stuck as to what to use.
Any assistance will help.
No data throughput has been provided.
1 REPLY
Re: Assistance with which switches/routers to use?
Hi Bay,
You can go for Cisco Catalyst 3750G-48TS which has 48 Ethernet 10/100/1000 ports and 4 SFP ports or all the floors and buildings.
You can use 10/100/1000 ports for users and SFP ports for fiber backbone.
You can also use these switches in stack fashion where you can stack 2 3750 one from each floor in one building together and same you can follow for all your buildings
http://www.cisco.com/en/US/products/hw/switches/ps5023/index.html
If cost is a factor in your setup you can also go for Cisco Catalyst 3560G-48TS which will again give you 48 Ethernet 10/100/1000 ports and 4 SFP ports but will not give you stacking capability.
http://www.cisco.com/en/US/products/hw/switches/ps5528/index.html
Ankur
*Pls rate all helpfull post
171
