Community Member
associating a port with MAC address
how can i do that in a switch?
i know of the command >mac-address-table
but what exactly i need to write in order to restrict FastEthernet0/1 to work only with MAC XXXX.XXXX.XXXX ?
Hall of Fame Super Blue
Re: associating a port with MAC address
You need to use port-security to restrict which mac-addresses can use that port.
I have attached a link to 3560 port seurity configuration which explains the concept of port security.
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_configuration_guide_chapter09186a008081db10.html#wp1038501
If you have a different switch just search on Cisco for "switch type + port security"
Jon
Hi, [PLS RATE if HELPS]
As a continuation of Jon.Marshall post,
Cisco has very famous feature called port-security to restict Switch port access based on MAC-Address of clients connecting to it.
You can specify the Security feature in such a way like if somebody violate the Security you can instruct the Switch to Shutdown the Interface and only the Administrator can re-enable the port manually.
Refer link below for further understanding:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a0080160a2c.html#wp1044659
PLS RATE if HELPS
Best Regards,
Guru Prasad R
Community Member
i know of port-security, i just want to know about the other method of associating a single MAC with a port.
You can use the mac-address-table static command. Attached is link for 3560 example.
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_command_reference_chapter09186a0080818708.html#wp2789851
As far as i know this does not restrict the port to just that mac-address though.
Jon
Community Member
Do i have to specify the vlan option? if ihave interface with no vlans how would the syntax be?
Community Member
So does this prevent other MAC addresses to access the port?
151
