01-08-2007 07:08 AM - edited 03-05-2019 01:39 PM
I have the configs for many of the switches below. I need to assure each VLAN and port is being copied (Spanned) to a destination port for an IDS.
What is the best method to identify ports that are not spanned? Since I have all the configs, I'd like to script this using regex. Does anyone have any ideas?
Model
3560
4006
WS-C2924-XL-EN (C2900XL series)
WS-C2948
WS-C3550-48-SMI (C3550 series)
WS-C4006
WS-C4503
01-08-2007 07:52 AM
If you want to SPAN for VOICE, i'd suggest you just span voice vlan, and nothing else. Also, 7 switches is not that many for the script. You'd spend more time writing a script than applying commands.
Nevertheless, normally "show vlan" and "show interface status" or "show port status" displays the values which you can then plug into the script.
01-08-2007 07:56 AM
"show monitor" command will show what is the span session running on each device and what is the Rx and Tx port configured for that particular span session.
