Community Member
authenticate telent access locally
I'm trying to authenticate telnet accesses to my core sw 4503 but to no avail, I've tried the same config on sw 3560 amazingly worked fine.
I know its straight forward config but it bugged me
1- create username/password
2- under line vty --> login local
any suggestions !!!
Hall of Fame Super Silver
Re: authenticate telent access locally
Hello Abu,
the config is fine but only if your device is not already using aaa new-model
you can verify with
sh run | inc aaa
if you find a line like
aaa new-model
you need to declare a list of authentication
methods:
conf t
aaa authentication login default local
aaa authentication enable default enable
or
aaa authentication login Locale local
line vty 0 4
login authentication Locale
Or
you do:
no aaa new-model
and use the classic pre-AAA config
Hope to help
Giuseppe
Community Member
Hi Giuseppe,
thx for ur input..
I've tried both ways,
1- with ** aaa new-model ** approach
I got the error msg ** % Authentication failed. **
2- with ** login local ** approach
I got the error msg ** % Login invalid **
any comments !!
Hello Abu,
1) % Authentication failed.
make sure the device is not asking to a tacacs+ server or radius first
the aaa authentication login provides an ORDERED list of methods: first method is used and only if unavailable the second is used:
example:
aaa authentication login default tacacs local
the local is used only if the tacacs is not configured or it is unreachable: during AAA tests I had to use tricks to verify the fallback to local mode when the server cannot answer
use multiple vty sessions to test, this is really handy.
Also it can be useful to know the supervisor model and IOS version you are running
For example on our 4506s we have:
aaa new-model
aaa authentication login ACS group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa accounting update newinfo
aaa accounting exec ACS start-stop group tacacs+
aaa accounting commands 1 ACS start-stop group tacacs+
aaa accounting commands 15 ACS start-stop group tacacs+
aaa session-id common
line vty 0 3
access-class 24 in
exec-timeout 15 0
accounting exec ACS
login authentication ACS
Hope to help
Giuseppe
268
