Community Member
Auto QoS - 3825 Router
I'm in the process of cleaning up some of the auto QoS configurations at some branch offices....while it was configured on the switchports none of the trunks appeared to have the auto qos voip trust config.
Do I need to enable auto qos on the router inside interface as well or just the switchport connected to it?
If I do need to apply it to the router do I apply it to the interface or the SVI?
1 ACCEPTED SOLUTION
Re: Auto QoS - 3825 Router
Only switch module ports on ISR supports "auto qos".
you can't enable auto qos on routed GIG port.
KK.
KK.
Community Member
That makes sense, thanks!
439
