auto QoS in physical Interfaces Switch 4507R+E
I'd like to take a doubt, I'm dealing with a customer that has a Core Cisco 4507R + E with 2 Sup WS-X45-SUP7-E and WS-X4748 line cards 3-RJ45-E with IOS version below:
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-
UNIVERSAL-M), Version 03.02.05.SG RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 31-Jul-12 11:17 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2010 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
Image text-base: 0x100A1A54, data-base: 0x13CCD2F8
ROM: 15.0(1r)SG5
Jawa Revision 7, Snowtrooper Revision 0x0.0x116
Core4500 uptime is 1 year, 2 days, 5 hours, 21 minutes
Uptime for this control processor is 1 year, 2 days, 5 hours, 23 minutes
System image file is "bootflash:cat4500e-universal.SPA.03.02.05.SG.150-2.SG5.bin
He is implementing ToIP. The topology is structured in the collapsed model where switches etherchannel uplinks have access to 2Gb Core.
On all access switches the "auto qos trust" for uplinks and the "auto qos trust cisco-phone" to access ports was implemented. In Core would have to disassemble the PortChannel, apply auto qos trust in the PortChannel interfaces and ride again.
The doubt is that setting the 4507R + E accepts the QoS on the doors of the Port Channel?
As this Release Notes http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/OL_27990-01.html
box in Release 3.2.3 does not support QoS on physical ports that composes the PortChannel.
Silver
Hi,  In this case as you
 In this case as you pointed out, Auto-QoS is not supported on EtherChannel or its member ports. A physical port configured with Auto-QoS is not allowed to become a member of a physical port.
See the link below where you can find details about QOS on etherchannel:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/3.1.1SG/configuration/guide/qos.html#wp1563359
Hope this helps.
I will have impact on voice
I will have impact on voice traffic due to lack of QoS in Core? loss voice or something ??
158
