auto qos in WS-C4507R
I need knows if this WS-C4507R support the command auto qos voip trust and what is the best way to configure QOS in the LAN.
------------------ show version ------------------
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(25)EW, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by Cisco Systems, Inc.
Compiled Fri 10-Dec-04 14:26 by kellythw
ROM: 12.2(20r)EW1
Dagobah Revision 95, Swamp Revision 6
8901SW254 uptime is 1 year, 25 weeks, 3 days, 1 hour, 32 minutes
Uptime for this control processor is 1 year, 25 weeks, 3 days, 1 hour, 32 minutes
System restarted at 10:22:00 UTC Thu Nov 2 2006
System image file is "bootflash:"
cisco WS-C4507R (MPC8245) processor (revision 8) with 524288K bytes of memory.
Processor board ID FOX0851021H
MPC8245 CPU at 400Mhz, Supervisor V
Last reset from PowerUp
8 Virtual Ethernet interfaces
58 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Chassis Type : WS-C4507R
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 2 Supervisor V 1000BaseX (GBIC) WS-X4516 JAB0905024M
2 2 Supervisor V 1000BaseX (GBIC) WS-X4516 JAB090604EF
3 24 10/100/1000BaseT (RJ45) WS-X4424-GB-RJ45 JAE084501JM
4 24 10/100/1000BaseT (RJ45) WS-X4424-GB-RJ45 JAE08501ZAQ
5 6 1000BaseX (GBIC) WS-X4306-GB JAE1123KT0L
M MAC addresses Hw Fw Sw Status
1 0013.1a1f.3b00 to 0013.1a1f.3b01 2.0 12.2(20r)EW1 12.2(25)EW Ok
2 0013.1a1f.3b02 to 0013.1a1f.3b03 2.0 12.2(20r)EW1 12.2(25)EW, Ok
3 0012.01f1.97e0 to 0012.01f1.97f7 1.6 Ok
4 0012.01f1.ccc0 to 0012.01f1.ccd7 1.6 Ok
5 000e.83a1.c4e8 to 000e.83a1.c4ed 4.3 Ok
------------------ show bootflash: all ------------------
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- name
1 .. image F0AB9628 C4C440 28 12370880 Feb 9 2005 04:23:53 -06:00 cat4000-i9s-mz.122-25.EW.bin
46873536 bytes available (12371008 bytes used)
anyone can help me?
Super Bronze
Re: auto qos in WS-C4507R
I'm unfamiliar with the 4500 series QoS specifically, or whether it supports any auto QoS features, but in general, either a two class model (real-time and BE), or a four class model (e.g. real-time, better than BE, BE and less than BE) model works well. (Many LAN switches that support QoS/CoS, usually only support two or four classes.)
How to use the four class model, real-time traffic, like VoIP in a LLQ class; really important/critical (and hopefully lightweight) traffic, like voice signally, in the better then BE class (minimal bandwidth guarantee sufficient so traffic usually doesn't queue); really bad traffic, like server network backups, in the less than BE class with a minimal bandwidth guarantee (perhaps only 1%); everything else in BE.
[edit]
PS:
The software configuration guides for your IOS version should have a section about QoS.
thansk for your reply, can you tell me how to find a configuration guide for my IOS version?
thanks
Super Bronze
253
