Community Member
Auto Smartports on Catalyst 2960
I don't know if what I am asking is possible but I thought I would ask.  I have mobile video conferencing equipment that could be plugged into any network jack in a building and I need to reconfigure the port on the fly.  I have successfully used Auto Smartports to configure the port to the proper VLAN when the equipment is plugged in.  The problem I am having is when I unplug the equipment, the switchport retains the current VLAN.  I would like the switchport to revert back to its original configuration including the VLAN it had before plugging the equipment in.
Hall of Fame Super Blue
Command:  default interface
Community Member
Thanks for the command but it removed all configuration for that interface back to factory default.  I want to keep all configuration including QOS, spanning-tree, etc.  I just want it so when I unplug the equipment, the data vlan goes back to the vlan it was before the equipment was plugged in but retain all the other interface configuration.
Community Member
Re: Auto Smartports on Catalyst 2960
No sure if you resolved your issue yet but noticed that no answer had yet been accepted so presume not
I believe you have to run an anti-macro to remove the commands added by your initial macro. The bit after the link down is considered to be the anti-macro
if [[ $LINKUP -eq YES ]]; then
    conf t
    interface $INTERFACE
    switchport access vlan 10
    exit
end
fi
if [[ $LINKUP -eq ]]; then
    conf t
    !switch back to the your default port vlan on link down
    switchport access vlan 20
    !or
    no switchport access vlan 10
    ! this will result with the port having no access vlan.
    exit
end
fi
Good luck
Dale
506
