automatic backup of catalyst 6500
Hey!
i have a EEM script that backups the running conf when entering command "write memory" to ftp server.
How can i modify it, that it would'nt copy the file over and over. Instead it would make the conf file with diffrent name or date.
Any ideas?
Silver
Re: automatic backup of catalyst 6500
You can have the EEM script append the current data and time to file name whenever a "write memory" is given so that every time a file with a different name will be created. Another workaround would be to manually rename or move the file after entering command "write memory".
Yep, at the moment cron changes the filename after it has been copied to backup server
HI karblane1,
This is Interesting.
Can you Please Provide me the Complete EEM Script you are Using.
Thanks in Advance for Help
Best Regards,
Guru Prasad R
hi,
we use a simple shel script, like this :
#!/bin/bash
umask 022
export DIR=/netmgmt
export ID=$$
export ROUTER=${1}
export DATEDIR=`/bin/date -I`
export COMMUNITY=${2}
export SNMPSET="/usr/bin/snmpset -m CISCO-CONFIG-COPY-MIB -v 2c -t 500"
export SNMPGET="/usr/bin/snmpget -m CISCO-CONFIG-COPY-MIB -v 2c -Ovque"
export SNMPWALK="/usr/bin/snmpwalk -m CISCO-CONFIG-COPY-MIB -v 2c"
export TFTPDIR=/tftpboot
#Write memory
echo "`date` $ROUTER:write memory" >> $DIR/log_backup/log-${DATEDIR}
${SNMPSET} -c ${COMMUNITY} ${ROUTER} .1.3.6.1.4.1.9.9.96.1.1.1.1.2.${ID} i 1 >> $DIR/log_backup/log-${DATEDIR}
${SNMPSET} -c ${COMMUNITY} ${ROUTER} .1.3.6.1.4.1.9.9.96.1.1.1.1.3.${ID} i 4 >> $DIR/log_backup/log-${DATEDIR}
${SNMPSET} -c ${COMMUNITY} ${ROUTER} .1.3.6.1.4.1.9.9.96.1.1.1.1.4.${ID} i 3 >> $DIR/log_backup/log-${DATEDIR}
#Start writitng
${SNMPSET} -c ${COMMUNITY} ${ROUTER} .1.3.6.1.4.1.9.9.96.1.1.1.1.14.${ID} i 1 >> $DIR/log_backup/log-${DATEDIR}
#Destroy MIB
OUT=`${SNMPGET} -c ${COMMUNITY} ${ROUTER} ccCopyState.${ID}`
while [ $OUT == 2 ]
do
done
${SNMPWALK} -c ${COMMUNITY} ${ROUTER} ccCopyState >> $DIR/log_backup/log-${DATEDIR}
if [ $OUT != 3 ]
then
echo -n "`date` ERROR: " >> $DIR/log_backup/log-${DATEDIR}
${SNMPWALK} -c ${COMMUNITY} ${ROUTER} ccCopyFailCause.${ID} >> $DIR/log_backup/log-${DATEDIR}
fi
${SNMPSET} -c ${COMMUNITY} ${ROUTER} .1.3.6.1.4.1.9.9.96.1.1.1.1.14.${ID} i 6 >> $DIR/log_backup/log-${DATEDIR}
#copyto TFTP
/usr/bin/touch ${TFTPDIR}/${ROUTER}
/bin/chmod 777 ${TFTPDIR}/${ROUTER}
#Prepare MIB
echo "`date` $ROUTER:copy startup tftp" >> $DIR/log_backup/log-${DATEDIR}
${SNMPSET} -c ${COMMUNITY} ${ROUTER} .1.3.6.1.4.1.9.9.96.1.1.1.1.4.${ID} i 1 >> $DIR/log_backup/log-${DATEDIR}
${SNMPSET} -c ${COMMUNITY} ${ROUTER} .1.3.6.1.4.1.9.9.96.1.1.1.1.5.${ID} a "172.18.253.47" >> $DIR/log_backup/log-${DATEDIR}
${SNMPSET} -c ${COMMUNITY} ${ROUTER} .1.3.6.1.4.1.9.9.96.1.1.1.1.6.${ID} s "${TFTPDIR}/${ROUTER}" >> $DIR/log_backup/log-${DATEDIR}
#Start writitng
#Destroy MIB
while [ $OUT == 2 ]
do
sleep 1
done
if [ $OUT != 3 ]
then
fi
/bin/chmod 640 ${TFTPDIR}/${ROUTER}
/bin/cp -p ${TFTPDIR}/${ROUTER} $DIR/conf_backup/${DATEDIR}/${ROUTER}
/bin/rm ${TFTPDIR}/${ROUTER}
and every night at 00:01 we run these 2 scripts:
#!/bin/bash
DIR=/netmgmt
umask 022
export DATEDIR=`date -I`
mkdir $DIR/conf_backup/${DATEDIR}
#!/bin/sh
# Only keep config 120 days back
DIR=/netmgmt
find $DIR/conf_backup -ctime +120 -exec rm -rf {} \;
404
