05-12-2008 12:17 PM - edited 03-05-2019 10:54 PM
I have a situation where I need to automate a vlan interface shutdown when an ip sla becomes true. Does anyone know of a procedure to do this?
Solved! Go to Solution.
05-12-2008 12:19 PM
Not too sure of your platform, but you can try using the EEM "Embedded Event Manager" This should allow you to accomplish what you are looking for! Hope this helps!
05-12-2008 12:19 PM
05-12-2008 01:03 PM
Thats what I needed. Thanks much...
05-12-2008 01:15 PM
No problem, and thanks for the nice rating.
