Aux power supply
tabail7690
I see there is a Aux power port on the back. Is there a power supply for a CISCO CATALYST 3560C PD 8PORT PSE to power it from a 110 VAC wall outlet or is only able to be powered through POE?
5 Replies 5
Reza Sharifi
Yes, you need to use the supplied AC power cord to connect the AC power connector to an AC power outlet.
There was not a power cord supplied.  It said it was sold separately but I can't find the part number.
It should comes in the box with the switch, if not you can ask your sales guy to provided to you.  There should be no cost to you.
No the manual says it is either powered over Ethernet or using a power adapter sold separately but it doesn't give a part number.
These items ship with the Catalyst 3560 8- and 12-port switches:
see this link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/hardware/quick/guide/3560gsg_08.html#wp53295
