Highlighted
Community Member
baby giant error
Which MTU size can cause a baby giant error?
A. 1500
B. 9216
C. 1600
D. 1518
what is the answer ?
Super Bronze
Re: baby giant error
C
Super Bronze
Standard Ethernet frame MTU is 1500 bytes. This does not include the Ethernet header and Cyclic Redundancy Check (CRC) trailer, which is 18 bytes in length, to make the total Ethernet frame size of 1518. In this document, MTU size or packet size refers only to Ethernet payload. Ethernet frame size refers to the whole Ethernet frame, including the header and the trailer. Baby giant frames refer to Ethernet frame size up to 1600 bytes, and jumbo frame refers to Ethernet frame size up to 9216 bytes.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-4000-series-switches/29805-175.html#topic3
Community Member
so answer is "D" right ?
No, when you look at what Joseph posted you would see this...
802.1q trunking 4 1500 + 4 + 18 = 1522 No MTU commands required.
So based on that the 1522 answer would not be correct because 1522 does not require any MTU changes. Also as Joseph pointed out Baby giant frames are up to 1600 bytes. Now based on all that frames that are 1523 to 1600 bytes would be considered Baby Giants.
Mike
Answer is C
Deepak Kumar
Community Member
i think answer should be "D".
What is you logic and documentation to support "D" as being the answer?
When the Cisco documentation says clearly "D" is not correct.
Mike
193
