back up of ios
sham_chennala
while i am trying to copy the ios of my 3750 swithch i am not able to locate the tftp server here i am pasting the output which i am geting. pls give help
YLE_Core_2#copy flash tftp
Source filename []? c3750-ipservices-mz.122-25.SEE2/c3750-ipservices-mz.
Address or name of remote host []? 122-25.SEE2.bin 192.168.0.145
?Invalid host address or name
%Error parsing filename (Invalid IP address or hostname)
YLE_Core_2#
5 Replies 5
mahmoodmkl
Level 7
Level 7
HI
R u able to reach the tftp server from this switch.
122-25.SEE2.bin 192.168.0.145 -here u need to just provide the ip address of the tftp server not the file name.
Is the TFTP server installed on the system.
Mahmood
S, i can able to reach the TFTP server but my problem is how to enter the name in that filed can you provide the cammands for taking the ios name from the DIR. In router we can directly copy the image name. here iam not able to paste the image name correctly. It covers the location where we want to specify the ip add of TFTP SERVER.
Pravin Phadte
Level 5
Level 5
You need to see if there is any acl blocking the tftp port fist then you should able to ping the tftp server.
Follow as below
Source filename:c3750-ipservices-mz.122-25.SEE2/c3750-ipservices-mz.122-25.SEE2.bin
File name which you need to copy to the tftp
Address or name of remote host: [tftp ip address]
Destination filename# [press enter]
Pravin
Hi pravin,
while i am pasting the image name to the source filename:it covers the remote host: portion also.But i heard from Flash DIR i can take the ios image name but i dont know how to take it from the DIR. If you know how to to take the back up from the 3750 switch ple provide the command also..
thanks & regards,
Sham.
try,
Copy flash:/c3name/ios.bin tftp:
give the ip address
give the name for file
It should get copied.
best way.
Copy flash:/c35 {press tab}/c35 [press tab] tftp:
the full file name will be shown.
Regrads,
Pravin
