Community Member
Backplane throughput determination
Is there a command I can run to see the total backplane throughput in use on Cisco Cat4006 Switches ?
Hall of Fame Super Silver
Re: Backplane throughput determination
Hello CCDE,
if IOS based
try with
sh platform health
in this lenghtly show there is a section about BW usage per slot
example
sh platform health | begin Allocation
Allocation ceiling Current allocation
kbytes % in use kbytes % in use
Linecard 1's Store 258.00 3% 9.92 100%
Linecard 2's Store 258.00 62% 162.09 100%
Linecard 3's Store 258.00 62% 162.09 100%
Linecard 4's Store 258.00 66% 171.03 100%
Linecard 5's Store 258.00 62% 162.09 100%
Linecard 6's Store 258.00 62% 162.09 100%
Hope to help
Giuseppe
Community Member
Do we know what the max througput is per slot for 4006.I could not find data sheets.It says total of 30Gbps backplane throughput
Hello CCDE,
a WS-4548 can do only 6 Gbps per slot also on a C4506 ( to be said)
So I would expect 6 Gbps per slot
Hope to help
Giuseppe
Bronze
Hi.
The maximum throughput in Cat4x00 series of switches is actually determined by the Supervisor used, and they are fixes at 6 Gbps per slot for all non-E supervisors, while the Sup6E gives 24 Gbps per slot in Cat4500E chassis.
HTH, Ingolf
Purple
If catos , the current usuage is shown with "show traffic" . If you need the total then you would have to look up the specs on the box on cisco.com .
Community Member
"show traffic" gives me nothing
214
