Bad Pings to PC
I'm pinging a device from a switch that keeps err-disabling from link flap. I've disabled link flap detect on the switch so it doesn't keep going down. The PC and switchport are both set to 100 full. I've moved the PC to a different switch and still the same result. When I first start pinging, the pings are pretty good. Then after a couple of minutes they start looking like below.
sh int fa0/41
FastEthernet0/41 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 0014.f27a.6b2d (bia 0014.f27a.6b2d)
  Description: EMSEDU
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:01, output hang never
  Last clearing of "show interface" counters 00:23:54
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 21000 bits/sec, 16 packets/sec
  5 minute output rate 10000 bits/sec, 17 packets/sec
     56388 packets input, 6961775 bytes, 0 no buffer
     Received 14 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     60233 packets output, 8935188 bytes, 0 underruns
Pings from switch:
Any suggestions?
Thanks, Pat.
  • LAN Switching and Routing
1 ACCEPTED SOLUTION
Purple
Re: Bad Pings to PC
Seeing that you changed ports it can only be cabling or a bad nic .
Purple
Re: Bad Pings to PC
Re: Bad Pings to PC
It was a bad cable. The bad cable was the one from the patch panel to the switchport. I should make a habit of including them in the test. I assume they are ok.
Thanks.
Silver
Re: Bad Pings to PC
Hi Patrick,
Please let us know what was the problem if you have resolved it. I am curious :). Thank you!
But Glen is right, it definitely seems like bad cable or PC network interface card.
Best regards,
Jan
194
