Bandwidth Calculation
My Question is what are the steps or ways to calculate link utilization of our Router or Switch ?
How can we judge the overall bandwidth consumption by traffic for data transfer on our device ?
Or is their any command with the help of which we can check our all link Bandwidth usage.
Rahul Chhabra
  • LAN Switching and Routing
Please check the below links
Please check the below links:
https://supportforums.cisco.com/discussion/11480871/bandwidth-utilization-calculation
https://learningnetwork.cisco.com/thread/38916
Hi Rahul, I dont think there
Hi Rahul,
I dont think there is any command which can give sum of all link utilization. Normally i get such requirement during -
- To check total traffic to the router before and after any configuration change (like major bgp change)
- If cpu is high due to interrupt.
How i do :
- show int | i input rate
- put output in to excel
- Use text to column and then get sum of rate
--Pls rate helpful posts--
Akash
60
