Community Member
Bandwidth command
Dear,
I have a Cisco 3845 and one of its Serial Ports is connected to the DR Site. I want to make sure that the link is really 2MBps or not. Is there a show command that would show this type of info?
swami
Community Member
Re: Bandwidth command
Try the sh int serial x/x
a small example of a T1 int is shown below
Router# show interfaces serial 0/0:0
Serial0/0:0 is up, line protocol is up
Hardware is DSX1
Internet address is x.x.x.x y.y.y.y
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, rely 255/255, load 9/255
Encapsulation HDLC, loopback not set, keepalive not set
Last input 0:15:34, output 0:00:00, output
hope this helps
Community Member
Dear ,
Thanks lot
Hall of Fame Super Bronze
Swami,
I'm afraid not. You can configure your WAN module for 2Mbps but if the ISP was not contracted for 2Mbps, you won't get that speed.
Best to contact the provider for that information. The router won't display that information via a show command.
You can find out the maximum throughput the WAN interface can provide by sending large amount of packets via that interface and observe when packets start dropping due to congestion. Once that occurs, you've reached the limit.
HTH,
__
Edison.
Community Member
hi,
if you are make sure that really 2 mbit/s or not, you may send a lot of packets to remote site by a third party software or ping command,
so the command based outputs may be indicate incorrect results.
so you can execute in a windows command prompt that ping -t remoteip -l 1500,
and you may start a lot of ping process(min 80-100)
alternativly, you can get that "wan killer" tool from internet
regards
ibrahim
Community Member
Dear,
Thanks. Let me try it out today
SWAMI
Hall of Fame Super Silver
Hello swami,
use sh controller serial x/y and check the received clock settings
this show provides useful L1 information like the type of cable connected and clock that is the L1 speed you want to check
BW in sh int is a configurable parameter that may be different from real link speed
Hope to help
Giuseppe
Community Member
Dear
i will try it today swamithen post you
153
