Community Member
Bandwidth limit and NAT
Just wander if somebody could help me.
I have router with three VLANs (1,2) for internal users NATed to external interface (gi0/0) with overload and VLAN (3) with public IPs routed through the same interface. I’ve created simple QoS policy which will match traffic using IP addressing and assigned it to Gi0/0 as below:
access-list 2103 permit ip host 83.16.91.2 any
access-list 2104 permit ip any host 83.16.91.2
class-map match-any VLAN3QoS
match access-group 2103
match access-group 2104
policy-map QoS
class VLAN3QoS
   police rate 1000000
     conform-action transmit
     exceed-action drop
interface GigabitEthernet0/0
service-policy input QoS
service-policy output QoS
This is working well. However when I try to do the same for private IP addresses:
access-list 2103 permit ip 172.16.1.0 0.0.0.255 any
access-list 2104 permit ip any 172.16.1.0 0.0.0.255
it doesn’t work at all unless I match traffic for any (access-list 2103 permit ip any any).
I believe problem is in NAT as external interface can’t recognize internal IP addressing. I know that I can assign the policy directly to VLAN1 and VLAN2 interfaces but I want to do this on Gi0/0.
Is any way to achieve this goal?
Thank you.
Everyone's tags (2)
229
