Bandwidth limit on catalyst 2960
Hi Friends,
I have ciscl catlyst 2960 8port switch, (flash:c2960-lanbasek9-mz.122-50.SE4/c2960-lanbasek9-mz.122-50.SE4.bin).
and in need to configure bandwidth limit for one of the port as a 1Mbps.
plz guide me steps for above same.
Thanks & regards,
Srinivas.
Thanks & Regards, Srinivas. N.
Well, if you want to limit bandwidth, it will drop excess usage, this is what you want to on the switch?
Re: Bandwidth limit on catalyst 2960
yes u r correct, plz let me know the config for the same.
i configured the below
class-map match-all 1024kbps
   description 1024kbps
   match ip dscp 0
policy-map 1024kb[s
   class 1024kbps
     police 1024000 exceed-action drop ( this is not accepting)
interface FastEthernet0/1
  service-policy input 1024kbps
  service-policy output 1024kbps  (this is also not accepting)
plz guide me.
Try this and let me know the result
mls qos
ip access-list standard IP_ANY
permit any
mac access-list extended MAC_ANY
permit any any 0x0 0xFFFF
class-map IP_ANY
match access-group name IP_ANY
class-map MAC_ANY
match access-group name MAC_ANY
mls qos aggregate-policer Policer-256 256000 32000 exceed-action drop
policy-map PMAP-256
class IP_ANY
  police aggregate Policer-256
class MAC_ANY
interface FastEthernet0/24
spanning-tree portfast
service-policy input PMAP-256
Rizwan Rafeek
Hi rizwanr,
finally i find the solution and testing also fine
i configure the below for port 0/1 or cisco 2960 switch.
exetuall i want restrict the 1Mbps on the above same port, my isp is 4Mbps
whin i configure the below download is restructed but up load is show nearly 5 to 7Mbps.
is there any other way to restruct the upload also
speed 10
srr-queue bandwidth limit 14
Hi Srini,
I am glad to hear that things worked out for you.
You must be originally from Sri Lanka? Are you?
1406
