Bandwidth limit on cisco 2950 switch
Srinivas N
Hi Friends,
I have cisco 2950 catalyst switch, verson
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(20)EA1a, RELEASE SOFTWARE
(fc1)
So. for one of my port (FE 0/3) i need to put the bandwith limit 512 kbps,
plz help me, how to configure the above same.
Note:- I configured the below but no effect
1. interface FastEthernet0/3
description * CONT TO B-CENTER *
switchport access vlan 10
switchport mode access
bandwidth 1024
speed 10
2. and there is no srr bandwidth limit option for 2950, but the same is working for 2960.
Srinivas. N
Thanks & Regards, Srinivas. N.
patrick.preuss
Hi Srinivas
normaly bandwidth has no effect for traffic it is used only for routing prorocols.
if feature set has it use "service-policy input policy-map-name "
Patrick
Hi Patric,
Thanks for your reply,
I have no knowledge in service-policy /input policy-map-name
So. please let me know to configure to sovle the above problem.
Srinivas.
you have to have at least
Q.    Do the Catalyst 2950 series switches support rate-limiting or policing on   ports or VLANs?
A. Catalyst 2950 series switches that run the enhanced image (EI) support       ingress policing on physical interfaces only. Policers do not have support on       VLAN interfaces. Catalyst 2950 series switches that run the standard image (SI)       do not support policing. The minimum release with support is Cisco IOS Software       Release 12.1.
and may be this discusion gives you an idea
https://supportforums.cisco.com/thread/27528
they work only incomming..
