03-26-2012 09:44 AM - edited 03-07-2019 05:47 AM
Hi Friends,
I have cisco 2950 catalyst switch, verson
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(20)EA1a, RELEASE SOFTWARE
(fc1)
So. for one of my port (FE 0/3) i need to put the bandwith limit 512 kbps,
plz help me, how to configure the above same.
Note:- I configured the below but no effect
1. interface FastEthernet0/3
description * CONT TO B-CENTER *
switchport access vlan 10
switchport mode access
bandwidth 1024
speed 10
2. and there is no srr bandwidth limit option for 2950, but the same is working for 2960.
Srinivas. N
03-26-2012 10:06 AM
Hi Srinivas
normaly bandwidth has no effect for traffic it is used only for routing prorocols.
if feature set has it use "service-policy input policy-map-name "
Patrick
03-26-2012 10:09 AM
Hi Patric,
Thanks for your reply,
I have no knowledge in service-policy /input policy-map-name
So. please let me know to configure to sovle the above problem.
Srinivas.
03-26-2012 10:25 AM
you have to have at least
A. Catalyst 2950 series switches that run the enhanced image (EI) support ingress policing on physical interfaces only. Policers do not have support on VLAN interfaces. Catalyst 2950 series switches that run the standard image (SI) do not support policing. The minimum release with support is Cisco IOS Software Release 12.1.
and may be this discusion gives you an idea
https://supportforums.cisco.com/thread/27528
they work only incomming..
