Bandwidth Limitation Per Static IP
I have Internet Link Speed 8MB on Cisco 1941 Router and i have internally 4 VLANS , each VLAN is Natted to Public IP address:
1. VLAN 10 should have 1MB Upload/Download BW , NATTED IP is 167.xx.xx.2
2. VLAN 20 should have 2MB Upload/Download BW , NATTED IP is 167.xx.xx.3
3. VLAN 30 should have 4MB Upload/Download BW , NATTED IP is 167.xx.xx.4
4. VLAN 40 should have 1MB Upload/Download BW , NATTED IP is 167.xx.xx.5
how to achieve the above scenario to divide the internet BW Related to each Public IP.
Small Example for the above scenario will be great.
BR,
1 ACCEPTED SOLUTION
This is the IP Telephony
This is the IP Telephony forum, you might want to move your thread.
java
if this helps, please rate
www.cisco.com/go/pdi
1 REPLY
java
