Bandwidth Testing on 3560 Switches
richard.kane
We are having problems with throughput on 3560 switches and I am looking for a way to evaluate the actual speed of gigabit links between switches. It looks like ttcp does not work properly for gigabit or else I don't know how to read the results. Is there another way to do it?
6 Replies 6
ropethic
Level 4
Level 4
This depends on quite a few variables:
1. What is the appliaction
2. Latency betweem two switches
3. packet queueing enabled
4. packet sizes?
Place as sniffer on one end to a SPAN port and to get a view of the traffic. Look for retransmissions, tcp window errors, etc.
Unfortunately you will need to dig a bit deeper to find a cause.
Iperf is a much better performance testing tool.
Thanks; it seems very good.
Thanks for the reply.
What is packet queueing?
Why the SPAN port with a sniffer? Doesn't the switch report all of those errors?
Please see url for explaination of different queue methods
http://www.cisco.com/en/US/tech/tk543/tk544/tsd_technology_support_protocol_home.html
Settting a span port to the sniffer will allow you to analyze the conversations traversing your link. The switch will not report Layer 4 errors. Users establish connections using TCP where each segment is assigned a sequence number. if packets are being delayed or dropped a retransmission will occur. The sniffer will identify these as retransmissions.
You can get wireshark sniffer for free.
Wireshark is a good tool for viewing output file. In a production environment where you
you have to view Gigabytes of data, I would
suggest you build yourself either a OpenBSD
box or Gentoo Linux box and use tcpdump for
this purpose. Tcpdump is best, bar none.
my 2c
