Webcast-Catalyst9k
banner problem catalyst 6509e
hi,
i trie to put in a banner on a catalyst 6509e. there is no error message at all. the banner i trie to put in works on other switches without problems.
but when i look at the config the banner entry is empty:
banner exec ^C
^C
banner login ^C
^C
the only that is different to all other switches is that this switch is in a VSS bundle.
(s72033_rp-IPSERVICESK9_WAN-VM), Version 12.2(33)SXI, RELEASE SOFTWARE (fc2)
any ideas, bug or ???, regards Reinhold.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: banner problem catalyst 6509e
Hello Reinhold,
there are bugs like
CSCei52830            Bug Details
Banner command sync is broken by CSCin86483
Symptoms: The banner motd command may not properly function when you enter a
message-of-the-day (MOTD) through the banner motd
d message d command because the d message
d
argument of the command may not be synchronized to the standby RP.
Conditions: This symptom is observed on Cisco router or switch that is
configured for SSO.
CSCsv54929            Bug Details
Cannot save banner bigger than 2048 characters
Symptom:
Banner bigger than 2048 chracters does not show up in show run after
a reload. "sh run" or "wr mem" reports traceback error.
or the following one:
CSCsu57889            Bug Details
banner exec CLI ignoring lines starting with #, !, and ;
Symptoms:
Banner lines starting with "#", "!", or ";" characters are not stored in the running configuration.
Conditions:
No specific conditions.
Hope to help
Giuseppe
Hello Reinhold,
there are bugs like
d
configured for SSO.
Symptom:
Symptoms:
Conditions:
Hope to help
Giuseppe
hi giuslar,
thanks for the quick answer. your answer was the solution. my text started with #. i changed this in $.
thanks again, regards Reinhold.
831
