Community Member
Bazzar routes on Sup720
I have these strange routes on a Native Sup720 Distribution that I can't figure out where they're coming from. They're all mostly /32's and they appear to be coming from L3 configured port-channels. Here's a couple of snapshots:
LOF14DISTRT1#sh ip route | inc 169.254
169.254.0.0/16 is variably subnetted, 740 subnets, 2 masks
C 169.254.45.122/32 [0/1] via 169.254.45.122
C 169.254.234.188/32 [0/1] via 169.254.234.188
C 169.254.185.239/32 [0/1] via 169.254.185.239
C 169.254.58.108/32 [0/1] via 169.254.58.108
C 169.254.56.110/32 [0/1] via 169.254.56.110
C 169.254.189.232/32 [0/1] via 169.254.189.232
C 169.254.91.14/32 [0/1] via 169.254.91.14
C 169.254.51.102/32 [0/1] via 169.254.51.102
C 169.254.27.78/32 [0/1] via 169.254.27.78
C 169.254.238.186/32 [0/1] via 169.254.238.186
C 169.254.125.41/32 [0/1] via 169.254.125.41
C 169.254.140.223/32 [0/1] via 169.254.140.223
C 169.254.118.37/32 [0/1] via 169.254.118.37
C 169.254.117.38/32 [0/1] via 169.254.117.38
There are a lot more of those and the cef table looks like this:
LOF14DISTRT1#sh ip cef unresolved
Prefix Next Hop Interface
169.254.1.43/32 10.0.0.13 (?) Port-channel30(deleted)
169.254.2.120/32 10.0.0.13 (?) Port-channel30(deleted)
169.254.2.126/32 10.0.0.13 (?) Port-channel30(deleted)
169.254.3.11/32 10.0.0.13 (?) Port-channel30(deleted)
169.254.3.163/32 10.0.0.13 (?) Port-channel30(deleted)
169.254.3.188/32 10.0.0.82 (?) Port-channel10
169.254.3.213/32 10.0.0.13 (?) Port-channel30(deleted)
169.254.3.254/32 10.0.0.13 (?) Port-channel30(deleted)
169.254.4.141/32 10.0.0.13 (?) Port-channel30(deleted)
169.254.4.178/32 10.0.0.82 (?) Port-channel10
169.254.4.197/32 10.0.0.13 (?) Port-channel30(deleted)
169.254.4.199/32 10.0.0.13 (?) Port-channel30(deleted)
169.254.5.13/32 10.0.0.73 (?) Port-channel16
169.254.6.35/32 10.0.0.13 (?) Port-channel30(deleted)
a Sample port where some of these entries are showing up on:
LOF14DISTRT1#sh run in po 10
Building configuration...
Current configuration : 230 bytes
interface Port-channel10
description p2p<->HUB09DISTRT1-a0-po10
bandwidth 2000000
ip address 10.0.0.81 255.255.255.252
ip ospf network point-to-point
ip ospf cost 100
appletalk cable-range 10-10 10.98
ipx network 10
end
Any clue is much appreciated.
Casey
Silver
Re: Bazzar routes on Sup720
Do you have a static route looking something like this:
ip route 0.0.0.0 0.0.0.0 Port-channel10
If so, every packet hitting this route will cause us to ARP for the end host, causing us to fill up our routing table with /32 routes, and fill up our ARP table.
To fix, point this route to the actual next-hop IP.
Community Member
The only static routes I have are two /32 routes:
ip route 10.3.14.247 255.255.255.255 Vlan359
ip route 172.23.1.47 255.255.255.255 Vlan318
The rest of my routing is connected/OSPF derived.
Casey
316
