Switching
Get 20% off switches when you combine Cisco solutions
Labels
We are seeing random high memory utilisation spikes on our Cisco 9200L switches, running version 17.9.4a. We thought this might be related to the application visibility that is pushed out to them via Cisco Catalyst Centre, so we disabled application ...
hi guys . i have a network with below topology. In the core layer, I want to have redundancy, which means that if the main core switch of my network has a problem, the backup switch will automatically enter the circuit. What method is there?
chpmotry by Level 1
  • 64 Views
  • 4 replies
Hello everyone, I have two cisco 3750 switches that are on stack with the below config Switch# Role Mac Address Priority State--------------------------------------------------------*3 Master 0017.5ae7.d500 1 Ready4 Member c062.6b8c.f200 1 Readyi wou...
joe5084 by Level 1
  • 61 Views
  • 1 replies
Hi All,I have a topology as shown below:The Firewalls A & B are running as active/standby. I have an etherchannel configured between L3 Switch A and Switch B. The switches also have HSRP running for various VLANs. The link between Switch and Firewall...
Ranjita by Level 1
  • 70 Views
  • 0 replies
  • 1 Helpful votes
Hi anyone can assist me on the VPC configuration ? The status not up. VPC Status : switch(config)# show vpcLegend:(*) - local vPC is down, forwarding via vPC peer-link vPC domain id : 700Peer status : peer link is downvPC keep-alive status : Suspende...
Muhd by Level 1
  • 124 Views
  • 4 replies
Hi guys, One of my friend is facing a issue and it seems quite weird.2 of his 9200 switches lost their configuration even though configuration was saved and even if for some reason switch restarted but they should not  loose its configuration. what c...
