Community Member
Best Eigrp practice question
Which practice is most prevalently used and ideal for setting up eigrp routing?
1. make all vlan's and interfaces passive, then allow each to be enabled and add a network statement to reflect the ip details on the vlan or interface
e.g
router eigrp 100
passive-interface default
no passive-interface vlan 25
no passive-interface gigabitethernet 1/4
network 10.55.10.0 0.0.0.3
network 10.55.25.0 0.0.0.255
no auto-summary
exit
2) Or is it better to do a passive-interface for all vlan's and interfaces and allow each interface by disabling the passive-interface and then have a network statement that has allow all e.g.
router eigrp 100
network 10.0.0.0 0.255.255.255
no auto-summary
exit
Please can you explain the merits and disadvantages of each method?
Dan
1 REPLY
Hall of Fame Super Bronze
Re: Best Eigrp practice question
Both options provide the 'passive-interface default' which is considered Best Practice while the first option provides a more granular control on the advertised subnets into EIGRP.
On the 2nd option, you are automatically advertising any local link within the 10.0.0.0/8 subnet into EIGRP.
In some networks, this can be flagged as a network security issue.
HTH,
__
Edison.
132
