Best Practices Metro Ethernet QoS?
pnicolette
Our sites connect via routers into a single Metro Ethernet (TLS) VLAN. The main site with most servers and the Internet link uses a 100Mb TLS circuit, same for another big site; the rest are 10Mb. Majority of traffic is outbound from main site to others. There's no VoIP, limited streaming video, but occasional congestion when a large file transfer hogs a 10Mb pipe with default FIFO queue.
Where to start for QoS?
Can the main site router enforce separate 10Mb output limits for each destination, even though they share one interface?
Or should I apply input service policies to the TLS interfaces of the other routers?
Or a better way....?
Thanks much for any ideas!
Paul
18 Replies 18
Thanks again!
Finally [thanks for your patience, hope this helps others]...
What are pros/cons in my mostly hub-spoke world of using dscp designations like cs1, cs2, cs3 versus the newer, more complex scheme like ef, af31, af11, be and such?
Actually you mean the pros/cons of DSCP vs. IP Precendence?
The former provides six bits for marking vs. only 3 bits for the latter. Using RFC recommendations, priorities overlap between the two and the additional DSCP bits are used for indicating drop precedence.
If you're going to mark at all, I would recommend using DSCP. Of course, you don't need markings to deliver QoS, it's just convenient for downstream devices (so they don't have to analyse the traffic again).
Hi Joseph,
I used your config for our qos environement which has a diagram below. Central and all branchs connected to ISP/MPLS cloud via metro ethernet lines witch different bandwidths. Central connected 100Mb, other branchs has different bandwidths.
We need QoS both central and branchs for especially voip RTP and signallling traffic. So i used your config but we have some problems.
As you see following outputs Class-map: Branch-A has 1024Kb bw and using 1024Kb bandwitdth but under Service-policy "queue",
Class-map: "realtime" and "signal" using 20000 and 5000Kb bandwidth. Actually i want to use 20% and 5% of 1024Kb.
What is the issue outthere?
Router:Cisco 3845
IOS:c3845-spservicesk9-mz.124-13f.bin
Thanks in advance.
Central_Router#sh policy-map interface g0/0
GigabitEthernet0/0
  Service-policy output: central
    Class-map: Branch-A (match-all)
      133672 packets, 93715046 bytes
      5 minute offered rate 372000 bps, drop rate 0 bps
      Match: access-group name Branch-A
      Traffic Shaping
           Target/Average   Byte   Sustain   Excess    Interval  Increment
             Rate           Limit  bits/int  bits/int  (ms)      (bytes)
        100000000/100000000 625000 2500000   2500000   25        312500
        Adapt  Queue     Packets   Bytes     Packets   Bytes     Shaping
        Active Depth                         Delayed   Delayed   Active
        -      0         133672    93715046  0         0         no
      Queueing
        Output Queue: Conversation 265
        Bandwidth 1 (%)
        Bandwidth 1024 (kbps)Max Threshold 64 (packets)
        (pkts matched/bytes matched) 454/409201
        (depth/total drops/no-buffer drops) 0/0/0
      Service-policy : queue
        Class-map: realtime (match-all)
          0 packets, 0 bytes
          5 minute offered rate 0 bps, drop rate 0 bps
          Match: ip dscp ef (46)
          Queueing
            Strict Priority
            Output Queue: Conversation 264
            Bandwidth 20 (%)
            Bandwidth 20000 (kbps) Burst 500000 (Bytes)
            (pkts matched/bytes matched) 0/0
            (total drops/bytes drops) 0/0
        Class-map: signal (match-all)
          0 packets, 0 bytes
          Match: ip dscp af31 (26)
          Queueing
            Bandwidth 5 (%)
            Bandwidth 5000 (kbps)Max Threshold 64 (packets)
        Class-map: class-default (match-any)
!---INPUT-----
policy-map mark
class RTP_AUDIO
  set ip dscp ef
class SIGNALLING
  set ip dscp af31
class-map match-any RTP_AUDIO
match access-group name rtp
ip access-list extended rtp
permit udp any any range 16384 32767
class-map match-any SIGNALLING
match ip dscp cs3
match access-group name signalling
ip access-list extended signalling
remark H323
permit tcp any any range 1720 1721
remark SKINNY
permit tcp any any range 2000 2002
permit udp any any range 1720 1721
remark MGCP
permit udp any any eq 2427
remark SIP
permit tcp any any eq 5060
permit udp any any eq 5060
!----OUTPUT-----
policy-map queue
class realtime
  priority percent 20
class signal
  bandwidth percent 5
class class-default
  fair-queue
class-map match-all realtime
match ip dscp ef
class-map match-all signal
match ip dscp af31
!---OUTPUT with BRANCH-----
policy-map central
class Branch-A
  shape average 100000000
  bandwidth percent 1
  service-policy queue
class Branch-B
  bandwidth percent 1
class Branch-C
  bandwidth percent 2
class Branch-D
  bandwidth percent 2
class-map match-all Branch-A
match access-group name Branch-A
class-map match-all Branch-B
match access-group name Branch-B
class-map match-all Branch-C
match access-group name Branch-C
class-map match-all Branch-D
match access-group name Branch-D
ip access-list extended Branch-A
permit ip any 10.34.128.0 0.0.7.255
ip access-list extended Branch-B
permit ip any 10.34.112.0 0.0.7.255
ip access-list extended Branch-C
permit ip any 10.34.152.0 0.0.7.255
ip access-list extended Branch-D
permit ip any 10.35.144.0 0.0.7.255
interface GigabitEthernet0/0
bandwidth 102400
ip address 172.100.0.2 255.255.255.248
service-policy output central
interface GigabitEthernet0/1
ip address 172.18.0.2 255.255.255.252
service-policy input mark
Solved after IOS upgrade, thanx.
