Best Way to Back-up the Cisco Devices (Routers or Switches)
Dear Sir,
Good Day!
What are the best way to back up all my Cisco Equipments? (Running Configuration, Startup Configuration, System Image & etc.)
My devices are:
1. Cisco 2900 Series - 2911
2. Cisco 2800 Series - 2811
3. Cisco Catalyst 3750V2 PoE
4. Cisco Core Switch 6506-E
Is there any different way to back up in every Device?
What are those commands and Purposes?
What are those need to be back-up in every Devices?
Thank you,
Best regards,
Michael
2 ACCEPTED SOLUTIONS
Best Way to Back-up the Cisco Devices (Router or Switches)
You can use something like RANCID for free:
http://www.shrubbery.net/rancid/
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Purple
In the url provided by john you have a link to this :
http://www.linuxhomenetworking.com/wiki/index.php/Quick_HOWTO_:_Ch1_:_Network_Backups_With_Rancid#.UtPhubQoIto
Alain
HTH,
John
Re: Best Way to Back-up the Cisco Devices (Router or Switches)
Dear Sir,
Thank you for speedy reply and Help..
I've downloaded the file .
rancid-2.3.8.tar.gz
But don't know how to use it. I'm not familiar in inux OS.
Do you have any procedure how to configure. Thanks in advance
Purple
Alain
Dear Sir,
Thank you for the help.
Very Interesting.. I will try linux OS to install.
but if you have for windows environment. Really appreciated.
Thank you,
Michael
Purple
I don't know of any free Windows tool that can do this but as you've got only 4 devices, you could run a kron job on each device that will save the configs regularly and just save the system image once with corresponding copy command.
Alain
Dear Sir,
How can I run that Software? Do you have any procedure?
Purple
kron:http://www.cisco.com/en/US/docs/ios-xml/ios/cns/configuration/xe-3s/asr1000/cns-cmd-sched.html
take note of the restriction about interactive commands so here to copy running to tftp you'll have to do this as command:
show run | redirect tftp://x.x.x.x  instead of  copy run tftp://x.x.x.x
You also have the Archive feature: http://www.cisco.com/en/US/docs/ios/fundamentals/command/reference/cf_a1.html#wp1018716
Alain
Hall of Fame Super Gold
You can also try this:
archive
log config
logging enable
hidekeys
path tftp:///$h-
write-memory
time-period 10080
Explaination:
There are two ways to save your config to your remote station:
1.  When someone saves the config; and
2.  At an alloted time period, expressed in 10080 (weekly for me).
Dear Sir,
Thank you for additional info.
I hope everyone found this useful.
353
