Best way to connect 2 Cisco 3750 PoE 24-port Switches
Hello. I have 2 Cisco 3750 PoE 24-port switches in a small office environment. Right now I have a trunk configured off my ASA 5505 to switch 1, and then just an access port configured on a port (switch 1) and an access port configured on a port (switch 2) to connect them together. These switches also have 2 GB SFP ports but they are not being used in this configuration.
I was curious to know if anyone had any better recommend configurations for connecting these 2 switches together? I'm not sure if this particular model can be stacked?
1 ACCEPTED SOLUTION
What are the exact model
What are the exact model numbers (should be written on a sticker)?
You will know if they can be stacked as you will see the 2x stack ports on the back of each switch :)
If they can then that is probably the way to go unless you want to keep them as separate switches for some reason.
If you want them separate, I would connect them via a Trunk link at least so you can have the same Vlans on both.
1 REPLY
192
