10-25-2013 01:09 AM - edited 03-07-2019 04:14 PM
Hi guys,
I have a site with 2 core switches and then about 20 edge switches hanging off this. At the minute all the VLANs are statically assigned on each switch but customer wants to implement VTP. The way I was going to go about this was to:
I assume I can also set both core switches as VTP server without issues so VLAN information will still be available in the event of a switch failure? They both have an indentical VLAN list at the minute so doesn't really matter which one has a higher RC and propogates.
Solved! Go to Solution.
10-25-2013 02:17 AM
Sean,
The plan what you have is looks good.
But why you want go with VTP I would highly recommend keep the edge switches in transperant mode I sean lot of outages due to VTP.
If it is highly concern then you are good to go with your plan.
Apart from your plan make sure the configuration revision number on the edge ones lesser than core. of course this may not cause anything as long as you kept them in transperant mode but just wanted to make sure everything is taken place before causing any issues.
Please rate the helpfull posts.
Naidu.
10-25-2013 02:17 AM
Sean,
Naidu.
10-25-2013 02:48 AM
Hi Naidu - I agree. I implemented the original install and chose not to use VTP, but the customer will be providing management and first line support through their own IT team and they want to have a central point of administration for VLANs going forward.
10-25-2013 06:16 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
VTP clients also share their VLAN database, so before flipping a transparent mode to client mode you may want to insure your current revision is > 1.
To make VTP a little more difficult to accidentally break you might also want to consider using VTP passwords or VTP version 3.
